9 Smart Query Panel Navigation
Displays the navigation keystrokes for the smart query panel.
Table 9-1 Smart Query Panel Navigation
Keys Action
F6 Switch between Smart Query and Office components
Ctl+Enter Set focus from a dimension down to its properties
Ctl+X and Ctl+V Move dimensions between axes (select dimension, Ctl+X to cut dimension, Tab to target dimension, then Ctl+V to paste dimension)
