Smart Query Panel
Displays the access keys for navigating in the Smart Query panel.
Keys Action
F6 Cycle through the active Excel ribbon tab; the active Excel sheet, and the sheet name; the task pane that displays the Smart Query Panel; and the Office status bar
Ctrl+Enter Set focus from a dimension down to its properties
Ctrl+X and Ctrl+V Move dimensions between axes (select dimension, Ctl+X to cut dimension, Tab to target dimension, then Ctl+V to paste dimension)
