JD Edwards EnterpriseOne Architecture and Process Flow for Windows
These host server processes perform the indicated actions:
All communications between the client and the host server occur using sockets. The communications between jdenet_n and jdenet_k occur with shared memory. jdenet_n and queue kernel communicate using the Job Control Status Master database table (F986110).
This text explains the process flow:
During Windows system startup, jdesnet runs automatically, provided that it is installed to start automatically. Otherwise, it must be started manually.
This information applies to the JD Edwards network service:
The program is system\bin32\jdesnet.exe.
Each time that a new server or workstation connects to this server, jdesnet might start another jdenet_n until the number of jdesnet and jdenet_n jobs equals the value in the maxNetProcesses field in the [JDENET] section of the JDE.INI file.
Each time that a new request, such as a batch application or CallObj is submitted, jdesnet (and any jdenet_n processes) might start another jdenet_k process until the number of jdenet_k jobs equals value in the maxKernelProcesses field in the [JDENET] section of the JDE.INI file.
Jdenet_n can be run manually by running system\bin32\jdenet_n.
This information applies to the JD Edwards queue service:
The program is system\bin32\jdesque.exe.
The service runs the number of instances of queue kernels specified in the UBEQueues, PackageQueues, and SpecInstallQueues fields in the [NETWORK QUEUE SETTINGS] section of the JDE.INI.
When a user submits a batch application, jdesnet or jdenet_n (as part of the host server) communicates with the client as follows:
The host server programs are system\bin32\jdesnet.exe and system\bin32\jdenet_n.exe.
The client environment is initialized.
The client tells the host server (using a socket) to initialize its environment.
The host server (for example, jdenet_n) initializes its environment and gets environment and user handles.
The host server passes the environment and user handles to the client (using a socket).
The client launches the batch application and then sends data to the host server (using a socket).
If the maximum number of kernel (for example, jdenet_k; the k stands for kernel) processes has not been met, jdesnet or jdenet_n might start a new jdenet_k process.
If the maximum number of jdenet_k processes has been met, jdesnet or jdenet_n puts the message in a queue for a jdenet_k process.
The client frees the user environment.
The client tells the host server (using a socket) to free the user environment for the server.
The host server frees its user environment.
The client tells the host server (using a socket) to free the environment for the server.
The host server frees its environment.
When the UBE Jdenet_k (the kernel) writes to the database (batch application only), this occurs:
The program is system\bin32\jdenet_k.exe.
Jdenet_k adds a record in the F986110 database table. The record has a status of W (Waiting).
The Queue Kernel periodically checks the contents of table F986110 and launches a runbatch process.
When runbatch processes the batch application, this occurs:
The program is system\bin32\runbatch.exe.
The system changes the status stored in table F986110 to P (Processing).
The system starts the batch application.
If the batch application completes successfully, it changes the status in table F986110 to D (Done).
If the batch application does not complete successfully, it changes the status in table F986110 to E (Error).
Unlike the many processes that execute when a batch application is submitted, jdenet_k performs the processing when a user submits a CallObject and these actions occur:
Cannot start the service name service on the enterprise server.
Error 1069: The service did not start due to a logon failure.
