Understanding Java Runtime Engine Installation Issue on Unix
With JD Edwards Tools release 8.98, the Java Runtime Engine is bundled into the tools code. It will be in the directory .../system/jre. However, the problem is that prior to Apps Release 8.12 the installer will not set all the correct paths for this. So if a customer is using 9.0 with Tools 8.98 they will most likely get an error like this from the JDE log:
12320/1 MAIN_THREAD Tue Nov 8 17:35:05.884717
ipcmisc.c299
process 12320 </u04/oneworld/e1t_owa_stageing_development/system/bin32
/jdenet_n> registered
in entry 0
12320/1 MAIN_THREAD Tue Nov 8 17:35:37.374029
netstart.c247
Failed to autostart kernel in range 29
and get a core file when the jdenet_k #29 tries to start. To fix this they will
need to add the path .../system/jre/1.4 to the LD_LIBRARY_PATH, LIBPATH, SHLIB_
PATH.
