Conversion Programs and Tables
Run the conversions in the order that they appear on the menu. If you do not use items and takeoffs, you do not need to run R44H96001, R44H96002, and R44H96003.
These tables are created from existing data in JD Edwards World:
Menu Option
Conversion Program
JD Edwards World Description
JD Edwards World Tables
Homebuilder Management Description
Homebuilder Management Tables
1
R44H9302
Community Master Conversion
F0006
F44H101
14
R44H9711
Create F44H711 Workfile Records
F4301/F4311 for lot start created commitment document types.
Create Conversion Lot Start Workfile Entries
F44H711
The Item Master (F4101) table has not changed and does not require conversion from JD Edwards World.
These tables are new in the Homebuilder Management system and are not converted from JD Edwards World:
Description
Explanation
Homebuilder Constants
F44H001
F4463
Manual setup
Vendor Assignment
F44H604
F4454
Manual setup
Homebuilder Activity Rules
F44H002
N/A
New table; manual setup
Extended Homebuilder Data Template
F44H0920
N/A
Extended Homebuilder Data Headings
F44H0921
N/A
F44H0929
N/A
Option Relationships
F44H402
N/A
Closing Worksheet Accounting Instructions
F44H590
N/A
Closing Worksheet Entries
F44H591
N/A
Closing Worksheet Data Mapping
F44H599
N/A
After Start Purchasing
F44H711P
N/A
New table; to be used forward
Construction Milestones
F44H790
N/A
New table; populated by a third-party scheduling system
These tables in JD Edwards World are not used in the Homebuilder Management system and, therefore, are not converted:
Description
Lot Proceed Detail Temporary
F4451T
Lot by Lot Tax File
F4460
Bid Master
F4464
Alternate Subdivision Maintenance
F4465
Media Object Storage
F4462
Takeoff Revisions
F4458
Lot Proceed Entry (History)
F4456
These conversion programs convert JD Edwards World A7.3 tables to JD Edwards EnterpriseOne tables. You must run each conversion program independently, not as a batch process.
When JD Edwards World tables contain a high volume of data, the conversion programs might run for an extended time. Allow adequate time to run and verify the results of the conversion before you use the Homebuilder Management system in a production environment.
You are strongly advised to back up the database before running the conversion programs.
