Conversion Programs and Tables
Run the conversions in the order that they appear on the menu. If you do not use items and takeoffs, you do not need to run R44H96001, R44H96002, and R44H96003.
These tables are created from existing data in JD Edwards World:
Menu Option |
Conversion Program |
JD Edwards World Description |
JD Edwards World Tables |
Homebuilder Management Description |
Homebuilder Management Tables |
1 |
R890006 |
Community Master Conversion |
F0006 |
F44H101 |
14 |
R44H9711 |
Create F44H711 Workfile Records |
F4301/F4311 for lot start created commitment document types. |
Create Conversion Lot Start Workfile Entries |
F44H711 |
The Item Master (F4101) table has not changed and does not require conversion from JD Edwards World.
These tables are new in the Homebuilder Management system and are not converted from JD Edwards World:
Description |
Homebuilder Management Table |
JD Edwards World Table |
Explanation |
Homebuilder Constants |
F44H001 |
F4463 |
Manual setup |
Vendor Assignment |
F44H604 |
F4454 |
Manual setup |
Homebuilder Activity Rules |
F44H002 |
N/A |
New table; manual setup |
Extended Homebuilder Data Template |
F44H0920 |
N/A |
Extended Homebuilder Data Headings |
F44H0921 |
N/A |
Extended Homebuilder Data |
F44H0929 |
N/A |
Option Relationships |
F44H402 |
N/A |
Closing Worksheet Accounting Instructions |
F44H590 |
N/A |
Closing Worksheet Entries |
F44H591 |
N/A |
Closing Worksheet Data Mapping |
F44H599 |
N/A |
After Start Purchasing |
F44H711P |
N/A |
New table; to be used forward |
Construction Milestones |
F44H790 |
N/A |
New table; populated by a third-party scheduling system |
These tables in JD Edwards World are not used in the Homebuilder Management system and, therefore, are not converted:
Description |
Lot Proceed Detail Temporary |
F4451T |
Lot by Lot Tax File |
F4460 |
Bid Master |
F4464 |
Alternate Subdivision Maintenance |
F4465 |
Media Object Storage |
F4462 |
Takeoff Revisions |
F4458 |
Lot Proceed Entry (History) |
F4456 |
These conversion programs convert JD Edwards World tables to JD Edwards EnterpriseOne tables. You must run each conversion program independently, not as a batch process.
When JD Edwards World tables contain a high volume of data, the conversion programs might run for an extended time. Allow adequate time to run and verify the results of the conversion before you use the Homebuilder Management system in a production environment.
You are strongly advised to back up the database before running the conversion programs.
