Running Post-Migration Tasks
Personnel
CNC Administrator
Logon Status
On a workstation, logged on as user JDE in the environment to which you are migrating data.
Prerequisites
Verify that Client Access ODBC data sources exist on the workstation for Business Data – <xxxx> and Control Tables – <xxxx>, where <xxxx> is the name of the temporary environment.
Table Conversion Workbench completed successfully.
Concurrent Tasks
None
For Oracle's JD Edwards EnterpriseOne 9.2 release, you must Fast Path to the Post Install Menu (GH9619), select World Post Migration Conversions and run the UBEs for the applications you have installed.
This example shows the Post Install menu:
For all conversion programs with a Table Conversion Prompting screen, select the “properties" check box and the “prompt for location" check box.
The properties for all Conversion Programs below that are marked with * must be run with the Input Environment set to the Temporary World environment – PYTEMP and the Output Environment set to the environment you are migrating data to – PY920. All other table conversions should have Input and Output Environment set to the same environment, which is the environment to which you are migrating data, PY920.
The location for all conversion programs below that are marked with “*" must be overridden to run locally.
Do not run conversions more than once.
