Subcontracting Conversion
To run option 6 on the menu G40UDM, perform these steps:
Before executing the subcontract conversion, use these commands to add triggers to the F00163 file.
ADDPFTRG FILE (F00163) TRGTIME(*AFTER) TRGEVENT(*DELETE) PGM(<XXXOBJ>/X0016C) RPLTRG(*YES)
Where <XXXOBJ> is the name of the object library (for example, JDFOBJ).
ADDPFTRG FILE(F00163) TRGTIME(*AFTER) TRGEVENT(*UPDATE) PGM((<XXXOBJ>/X0016C) RPLTRG(*YES)
If you execute option 6 and option 7 on menu G40UDM, perform the following after running the job:
RMVPFTRG F00163
Each job has a menu message. For the Application Conversion jobs, there should be information regarding Who Should Run the Job, What the Job Needs and Why the Job Should Be Run. Read the menu messages carefully before executing the job.
