Understanding Cross-References for Transaction Nature Codes
JD Edwards EnterpriseOne uses three digits for Transaction Nature Codes and two digits for Transaction Nature Suffixes. However, some states in Brazil require a four-digit code to define the Transaction Nature. You can use the CFOP From/To Maintenance – Migration program (P76B2002) to create a cross-reference between the standard three-digit and two- digit codes in the JD Edwards EnterpriseOne software and the four-digit codes that are required for Brazil. You set up the cross-references by company.
