Starting with Tools Release 9.2.8, you can use Centralized Configuration in Management
Console to configure default configuration settings across EnterpriseOne Enterprise,
BSSV, and Transaction servers. Centralized Configuration enables you to configure server
settings from a single location that can be applied to all the Enterprise, BSSV, and
Transaction servers assigned to a server group.
Note: Release 9.2.8
extends the capability of Centralized Configuration to all the EnterpriseOne
servers. If you have enabled Centralized Configuration in the previous Releases
9.2.7 or 9.2.7.3, the Centralized Configuration will be automatically enabled for
all the EnterpriseOne servers in Release 9.2.8. Alternatively, with Tools Release
9.2.8, you can perform a Change Component operation on the existing server instances
which enables Centralized Configuration. Change component will make all the current
configuration entries in database as instance level configuration. See Using
Centralized Configuration for EnterpriseOne HTML Servers (Release 9.2.7) for
details.
After you enable the Centralized Configuration, the group level default configuration
settings will be applicable to the server group as well as all the server instances in
that server group. Any changes made on the configuration of server groups will be
applicable to server instances as well. However, if you change the configuration
settings at instance level, the system overrides the group level configuration settings
and uses the instance level configuration. You have the option to restore the default
group level configuration settings for such instances. See Understanding How to Restore
Group Default Settings for Enterprise, BSSV, and Transaction Server Instances for
details.
