Identifying the Problem and Solution
Begin the analysis by identifying the problem or the data gap, and then identify how you want to use the data in EnterpriseOne, or in other words, determine which EnterpriseOne business process or transaction you want to invoke.
Example: Company A's Problem and Solution
Problem
Company A currently uses sensors to detect issues in certain assets to prevent potential breakdowns. Specifically, the company uses vibration and temperature sensors on various pieces of equipment. The data read from the sensors is not tied into their EnterpriseOne system; instead, it is integrated with a third-party software program that an operations manager has to access several times a day to monitor equipment. It would be ideal if the company could eliminate the need to use a disparate software program to manually oversee the performance of its equipment.
Solution
Company A wants to design a process that uses the EnterpriseOne Condition-Based Maintenance program for monitoring. With the Orchestrator Studio, Company A can create an orchestration with rules and conditions that:
Invoke a transaction in EnterpriseOne Condition-Based Maintenance that sends a warning message if vibration or temperature levels are within a certain range above normal operating levels.
Invoke a transaction in EnterpriseOne Condition-Based Maintenance that sends an alarm message if vibration or temperature levels exceed a certain level.
