Starting and Stopping Jobs using Scheduler
Using the Scheduler user interface, you can start and stop the orchestration jobs that have a schedule attached.
To start an individual orchestration job:
Open the Scheduler user interface.
Select the orchestration job you want to start.
Note: You can only start the jobs that are associated with the currently logged-in user, the currently used environment, and the user's current role. The currently logged-in user cannot start the jobs that are created by another user.For the selected job, slide the toggle to the right in the Started column.
Alternatively, you can click the Start selected button to start the selected orchestration job.
To start multiple orchestration jobs:
Click the check box next to the Type column to select the orchestration jobs you want to start, or click the Select All check box to select all the jobs.
Note: You can only start the jobs that are created by the currently logged-in user, the currently used environment, and the user's current role. The currently logged-in user cannot start the jobs created by another user.For the selected orchestration jobs, click the Start selected button to start the jobs.
To stop orchestration jobs:
Select the orchestration jobs you want to stop.
Note: You can stop all the jobs that are created by the currently logged-in user, regardless of the environment in which the user is logged in, and role the user is logged in as. The currently logged-in user cannot stop the jobs created by another user.For the selected orchestration jobs, click the Stop selected button to stop the selected jobs.
To stop an individual orchestration job, slide the toggle to right in the Started column for selected row.
