Understanding System Controls for Human Capital Management
This table lists and describes the data items that you can activate for specific processes in the Human Capital Management (HCM) and Payroll applications:
Action |
Data Item |
Usage |
To activate the French Canadian-Specific HCM Fundamentals system |
SY05QU (Use HCM Foundation-French CDN Specific) |
Set this data item to Yes if you have the French Canadian version of the JD Edwards Human Capital Management Foundation. Perform this action in addition to entering the Country Code on the User Profile Revisions form. |
To activate the U.S.-specific HCM Fundamentals system |
SY05U (Use HRM Foundation - U.S. Specific) |
This data item allows the system to provide U.S.-specific fields and forms in the JD Edwards EnterpriseOne Human Capital Management Foundation system. |
To activate the Canadian-specific HCM Fundamentals system |
SY05C (Use HRM Foundation - Canadian Specific) |
This data item allows the system to provide Canadian-specific fields and forms in the JD Edwards EnterpriseOne Human Capital Management Foundation system. |
To activate JD Edwards EnterpriseOne Payroll B73.3 or later |
SY07P733 (Use E1 Payroll B7.3.3 Or Later) |
Set this data item to Yes if you are using JD Edwards EnterpriseOne Payroll B73.3 and above. If this data item is set to Yes, the system searches for history records in the F07* tables. If this data item is set to No, the system searches for history records in all of the tables that begin with F06. |
To activate the Criterion module |
SY05CRTN (Use Criterion Integration) |
Set this data item to Yes if you are using Criterion BluePrint |
To activate the Personic module |
SY05PRSC (Use Personic Integration) |
Set this data item to Yes if you are using Personic Workflow. |
To activate Wage and Salary Administration |
SY08W (Use HRM Wage & Salary Administration) |
This system control will be available in a future release. |
To activate the Quantum GeoCoder |
HRGEO (Use GeoCoder for Tax Area in HR Apps) |
Set this option to Yes to use the Quantum GeoCoder to automatically assign tax area information to employee and business unit records. This option is available for U.S. and Canadian Payroll only. |
