Using the Adobe SVG Viewer on Web Clients
Per the Minimum Technical Requirements (MTRs) for JD Edwards EnterpriseOne web clients (refer to the section of this guide entitled: Accessing Certifications), you must have the Adobe Scalable Vector Graphics (SVG) viewer installed on your web clients in order to use specific JD Edwards EnterpriseOne applications, such as Demand Flow Manufacturing.
Within such JD Edwards EnterpriseOne applications, the Graphical Product Synchronization uses the Adobe SVG viewer for displaying the graphics associated with the product synchronization. The JD Edwards EnterpriseOne application automatically detects the Adobe viewer if it is already installed for the browser. If the viewer is not installed for the browser, the system displays a link that you can use to install the viewer from the Adobe web site. The URL for this link is:
http:\\www.adobe.com\svg\viewer\install\main.html
SVG is a graphics file format and
web development language based on XML that enables dynamic creation of high-quality
graphics with precise structural and visual control. It is based on standards
defined by the World Wide Web Consortium (http:\\www.w3.org\TR\SVG\
The installation of the SVG viewer may require administrator authority on your client machine.
