Abnormal Program Termination - jt400.jar and/or utill.jar Missing
If you receive the following message, it indicates that you have failed to correctly copy
the jt400.jar
and util400.jar
into the
..\stage\ext\jlib
directory. To remedy, you must copy these files
to the appropriate directory, exit from the installer, and restart the installer.
![This image is described in the surrounding text.](images/ibm_error_no_jar_files.gif)
