Adding an Entry for a Remote Database Directory for Vertex
To add an entry for a remote database directory:
Log on to the IBM i as QSECOFR.
On the command line, enter:
WRKRDBDIRE
Look for an entry on your IBM i for Remote Location *LOCAL. This entry must have the same name as your machine.
If you do not have an entry like this, enter 1 in the Option column and enter the machine name in the Relational Database column, and press enter.
In the Remote Location Name or Address enter *LOCAL and press Enter. If you already have a *LOCAL entry and the Relational database name is NOT the same as your machine name, you must remove the entry that you have and add a new entry as above.
