Alternate Language Components
An alternative language component is not included in this release; you must build the language package.
An alternate language includes major components whereby language text is stored in the Central Objects, System, Control Table, and Data Dictionary data sources. The data is loaded to the Deployment Server during the installation and copied to the Central Objects and the other data sources through the language installation process.
For Release 9.2, JD Edwards EnterpriseOne is shipped with 21 languages. Single-byte languages run on single-byte or double-byte operating systems, but double-byte languages must run on double-byte operating systems.
Instructions in this guide explain how to set up these features.
See Also
Package Build in the JD Edwards EnterpriseOne Tools Package Management Guide for more details on how to build a language package.
