Checking for Co-existence Tables
Before running the Table Conversion Workbench, you must check whether any of your tables are in Co-Existence (DDS) format. If you run Table Conversions against DDS format tables it will lead to data corruption and cause TCs to fail.
Use this procedure to check for co-existence tables:
Log on to the IBM i as QSECOFR.
On the command line, start a SQL session by entering this command:
STRSQL
Run the following SQL statement, substituting in your Control Tables and Business Data library names
SELECT TABLE_SCHEMA, TABLE_NAME, TABLE_TYPE FROM SYSTABLES WHERE TABLE_SCHEMA IN ('PRODCTL','PRODDTA') AND TABLE_TYPE = 'P'
where
TABLE_TYPE='P'
is DDS (World-created) tablesTABLE_TYPE='T'
is SQL (EnterpriseOne created) tablesIf there are DDS created tables in these libraries, you must follow the additional procedures in the Co-Existence Upgrade Guide (Doc ID: 702770.1), which is located on My Oracle Support.
