Deleting Machines from an Installation Plan
As you work through the Installation Planner application, you might find that you need to delete a server or machine that you have created. You can use Installation Planner to delete machines as needed; however, doing so can affect related databases, shared Enterprise Servers and Deployment Servers, and associated records.
To delete machines from an installation plan:
In the Release 9.2 planner environment, enter P9654A in the Fast Path field and press Enter.
On Work With Locations and Machines, click the Find button.
Expand the location.
A list of your locations, machines, or servers appears for the base location in the tree view.
Select the location, machine, or server that you want to delete.
Click the Delete button.
To close the application, click the Close button.
