Errors and How to Resolve Them
Most failures on these reports result from attempting to merge data items that do not exist in the target data dictionary into JD Edwards EnterpriseOne. These failures are normal and can be ignored. If every item on the report lists a merge status of "failed," then the source data dictionary could not be found to perform the merge. Verify your source data dictionary and run the merge again.
