Export Tablespace Script (detach_planner.bat)
To use the export tablespace script:
Edit the
jdedwards\E920\planner\data\detach_planner.bat
file such that any tablespaces that you do not intend to import are commented out. These lines start with:call %DATA_PATH%\EXPORT_TABLESPACE.BAT
Open a command prompt window by right-clicking on a Command Prompt shortcut and selecting Run as administrator.
Change directory to the location of the batch files.
Run the batch file to import the tablespace using this syntax:
detach_planner.bat <E1_install_dir>
For example:
detach_planner.bat c:\JDEdwards\E920
Note: This export batch file for the local metadata repository is in the spec directory:detach_metadata.bat
