Finalizing the Installation Plan
Installation Planner finalizes your installation plan automatically. A message appears to let you know that the installation plan is finalized.
When the plan is finalized:
  • The \JD Edwards\E920\hosts\hosttype\hostname directory is created on the Deployment Server. This contains the jde.ini and the configuration files used by the JD Edwards EnterpriseOne Platform Pack Installer.
    The JD Edwards EnterpriseOne Platform Pack Installer cannot be run until the Installation Plan is finalized.
  • The status is set to 20, which signals that several adjustments to tables were made according to your plan.
  • Create the OCM.
  • Modify the jde.ini.
  • The following tables are upgraded:
    • Release Master table (F00945)
    • Path Code Master table (F00942)
    • Package Plan table (F98404)
    • Machine Detail table (F9651)
    • Language table (F984031), if you are installing an alternate language
To finalize the installation plan:
  1. Click OK to exit the concluding message box and initiate the Planner Validation Report.
    • If you chose the default processing option, Planner Validation Report automatically prompts you to run this report.
    • If you did not choose the default processing option, on the tree view of your plan, click Validate to initiate the Planner Validation Report.
