Fonts and Type Styles
Special fonts and type styles are used in this guide. Nearly all of the commands in this guide are case sensitive. Enter them exactly as written. In addition, all of the commands described illustrate the recommended directory structure. If your machine's directory structure is different, modify the commands to match your directory structure.
Italic type style designates variables used in the guide. For example, for the variable deployment_server in a command, substitute the actual name of your Deployment Server. Also, the names of other JD Edwards EnterpriseOne guides are in italic type style. For example, JD Edwards EnterpriseOne Tools Package Management Guide.
Courier font indicates explicit file names, commands, or other information that must be
typed into the system. For example, a common file name used by JD Edwards EnterpriseOne is
an initialization file called the jde.ini
