General Checklist and Considerations
You should review this section prior to beginning an upgrade to the production environment.
Copying Central Objects, Object Librarian, and Packages
You can copy Business Data, Control Tables, Central Objects from PY920 to PD920 using UBE R98403:
XJDE0019 to copy Central Objects
XJDE0021 to copy Business Data
XJDE0022 to copy Control Tables
Alternately, you can run SAVLIB for these libraries:
- CRPDTA
- CRPCTL
- COPY920
Then restore the above libraries respectively as:
- PRODDTA
- PRODCTL
- COPD920
Copy ESU History
Run R9672 to copy ESU history. Be sure to change the Processing Options appropriately.
Run R989861 to copy the Object Librarian Check-in records.
Signon security
You should turn off the Security Server when you are running the Installation Workbench. Otherwise, security issues may occur while the Installation Workbench is running. If you have changed the password for JDE in your Enterprise Server database on your IBM i you should sign into the Deployment Server using the correct password for the Enterprise Server. For example, JDE APPLES JDEPLAN. You should add any passwords that have changed since the initial install and which might be used during the upgrade process to the
JDE.INI
on the Deployment Server in the[DSPWD]
section. For example:[DSPWD] JDE=APPLES PRODDTA=SNOOPY
Initial Tasks Workbench
Most of the processes in the Initial Tasks Workbench will be marked as Duplicates and will not run again. The Release Master (B9800400) runs every time. If you are upgrading from Xe or ERP8, you will need to run the Media Objects conversion for your business data. You should edit the Upgrade plan to change the status of R8900165 to 30. When the workbench runs, it presents a confirmation window telling you this conversion has already run. You should click Cancel to force the process to run the conversion.
Control Table Merge
If you copied the Control Tables in the Environment Copy application, in that application you should modify the Advanced options for your environment to uncheck the Control Table Merges. If you already finalized the plan, you will need to re-finalize the plan for this change to take effect. Alternatively you can mark all the Control Table Merges as having run by changing their status to 60.
The Upgrade plan will schedule the Table Conversions for your production data.
Specifications Merge
By default the Installation Planner will not schedule a Specifications Merge for your PD Upgrade plan. If you are upgrading any other environment, and have copied your Central Objects during Environment Copy, you should set the status of the Specifications Merge to 60 before running the Workbench.
Log all JD Edwards EnterpriseOne users off
Ensure that all JD Edwards EnterpriseOne users are logged off when running the Installation Workbench for the production upgrade.
