How to Read the Report
Each report has a cover page that contains a summary of and basic information about your upgrade, release information, source mappings, mappings from replication, additional table mappings, and the mode in which the report was run.
The main text of the report indicates the status of Environment and Release Information, Source UDC Table Mappings, UDC Table Mappings from Replication, Additional Table Mappings, and Mode.
If the entire merge is successful, a message appears at the end of each report:
  • For the UDC Merge and Exception report: "UDC Merge process completed successfully with no errors and warnings."
  • For the Data Dictionary Merge report: "Data dictionary merge process completed successfully with no errors and warnings."
  • For the Menu Merge report: "Menu merge process completed successfully with no errors and warnings."
Note: If you have made custom modifications to your business data, you can use the Application Configuration Analyzer to verify that your changes were carried forward to the new release. The Application Configuration Analyzer is a set of reports which identify differences for processing options, data dictionary (DD) items, and user defined codes (UDCs) between releases or environments. These reports are: See Also
