How to Read the Report
This report is designed to help you review the objects that will be merged. If the report shows any objects that you do not want to be merged, you can change the modification flag and the merge option so that the modification will not be merged into the new release. Similarly, you can verify that all modifications you want to be merged into the new release are flagged appropriately.
Two sets of headings appear on this report: one for the modified object, and a subheading for the modified components of that object.
Object headings
Description
Obj Type
Type of object. For example, APPL for application or BSFN for business function.
Object Name
Alphanumeric identifier for the object.
Member Description
Brief description of the object.
Syst Code
Product code the object belongs to.
Location
The machine the object is on, which is typically the Deployment Server.
Path Code
Path code in the previous release that the object belongs to.
Mod Flag
Whether the object has been changed (C).
Mrg Opt
Whether the object will be merged (1 is yes, 0 is no).
Date Modified
Last date the object was changed.
Component headings
Description
Object Component
Part of the object that was changed or added (for example, forms and event rules).
Status
Successfully read components will have a status of changed or added. If the status is "failed," the batch application could not read the modified component.
Description
Brief description of the change. If the status is "failed," the description will be a brief explanation of the error. These errors usually result from a failure to read the file.
The report includes the status of the following record types:
  • Package names
  • Source environments
  • Target environments
  • Advanced options
The report is broken into four sections:
  • The first section is a cover page which summarizes the processing options used to generate the report.
  • The second section is a list of the completion statuses of these objects as described in this table:
    Object
    Status
    Description
    Object Librarian
    Success
    Indicates the number of objects successfully added or updated.
    System 88 Warning
    Indicates the system detected custom modifications for an object in a JD Edwards EnterpriseOne product code that does not exist in the new Object Librarian. Object Librarian objects were obsoleted by JD Edwards EnterpriseOne, so you, as the customer, need to decide how this affects your procedures.
    Errors: Setup issues
    Indicates setup issues. To verify that your setup is correct you should:
    • Verify access authority to the source and target Object Librarian.
    • Check the JDE.LOG for insert or delete errors on the F986* tables.
    Versions List
    Success
    Indicates the number of copies successfully added or updated. Specification Merge totals indicate the number of added, replaced, and merged objects.
    PO Change Warning
    Indicates the processing options format for a ZJDE version has changed. Review and update options on these versions.
    Errors
    Indicates the number of errors that occurred during the merge. Check the JDE.LOG for more complete messages dealing with F983051 or F98306.
    Central Objects
    No Action Taken
    This category is applicable for ZJDE versions. It shows that the version data was transferred but that no specification merges occurred.
    Warnings and Errors
    Indicates that details for warnings and errors occured. You can locate these in the detailed fourth section of the report.
    Not Processed
    Indicates that the merge did not finish. Evaluate the errors and rerun the merge using a Restart version number.
    In Process
    Indicates a fatal error occurred in the merge business function before completing the object. Evaluate and fix the error conditions before restarting the merge.
  • The third section summarizes the merge statuses of each object in one line per object with these column headings:
    Object headings
    Description
    Obj Type
    Object type, such as BSFN is a business function and TBLE is a table.
    Object Name
    Version
    The report version number run for this object.
    Syst Code
    Product code.
    Merge Action
    Indicates the object on source was added, replaced, or merged on the target.
    Object Librarian Merge
    Completion status for Object Librarian updates for this object.
    Versions List Merge
    Completion status for Versions List updates for this object.
    Merge Status
    Completion status for Specification merge for this object.
    Date Completed
    Date the object was merged.
    Time Updated
    Time the object was updated.
  • The fourth section contains detail information for each merged object and includes these common errors:
    • Insert errors.
    • Header and source files that fail to copy.
    • Invalid dictionary items for tables or views.
    • Invalid files name or column in business views.
This table explains the column headings in the section:
Object headings
Description
Object Name
Version
The report version number run for this object. "+" indicates a template for a report.
Obj Type
Object type. For example, BSFN is a business function and TBLE is a table.
Syst Code
Product code.
Merge Action
Indicates the object on target source was added, replaced, or merged.
Merge Status
Success means that the object and all modified components were merged successfully. Warning means that one or more components did not merge correctly.
Mod Flag
Modification flag.
Date Completed
Last date the object was modified.
Time Updated
Last time the object was updated.
This table describes the column subheadings:
Object headings
Description
Description
Type of object component, such as a template, a field or an event rule.
Status
Status of the merge for that particular component. Success is denoted by a status of Added or Changed. Unsuccessful merges are noted with Failed or Error.
Description
This can be a brief description of the component or, in the case of a failure, an error message describing the failure. Disable and Append indicates event rules which require developer fixes.
