Preparing for Development Client Installation
To prepare for the installation of Release 9.2 on Development Clients,
you must modify the Development Client JDE.INI
on the Deployment Server
and the JD Edwards EnterpriseOne system administrator must create a user profile for
every user before that user can log on to Release 9.2. You must also
copy the configured tnsnames.ora
from the
oracle\E1local
directory to the \client
directory
on the Deployment Server, as specified in the next section of this chapter entitled:
Working With Development Client Installation
Prerequisites
Uninstall the previous software version on each Development Client before installing the new version. See Uninstalling the Software for more information about uninstalling previous releases of JD Edwards EnterpriseOne.
Before installing Release 9.2 on a Development Client used for development, you must install the Microsoft Visual C++ Compiler. The specific version of the compiler is detailed in the Minimum Technical Requirements (MTRs). Refer to the section of this guide entitled: Accessing Certifications. Also refer to the appropriate Microsoft documents for installation information.
The names of the Deployment Server, Enterprise Server, and the Development Client cannot exceed 15 characters in length.
IPv4 Requirement
The Development Client requires Microsoft Windows IPv4 for connectivity. It cannot function with IPv6. Refer to the JD Edwards EnterpriseOne Development Client Installation Guide for Oracle WebLogic Server (WLS) and WebSphere Application Server (WAS) Express details.
During Development Client installation, connectivity is required for:
Read/write access to this client install directory on the primary Deployment Server in the base location:
\oneworld
Read access to the subdirectories located under this directory:
\pathcode\package
For example:
\\deployment_server_name\E920\PD920\package
Read/write access to this directory on the primary Deployment Server:
\client
For example:
\\deployment_server_name\E920\client
Refer to the JD Edwards EnterpriseOne Deployment Server Reference Guide for Enterprise Systems for Microsoft Windows in Setting Up a Development Client Installer on the Deployment Server for these topics:
Refer to the JD Edwards EnterpriseOne Development Client Installation Guide for Oracle WebLogic Server (WLS) and WebSphere Application Server (WAS) Express for these topics:
