Rebuilding Cross Reference Tables on the IBM i
To rebuild cross reference tables on the IBM i:
Stop all subsystems using this command:
ENDSBS *ALL *IMMED
After the jobs have successfully stopped, run the following command:
RCLSTG SELECT(*DBXREF)
Note that this command may run for as much as several hours.
Restart all subsystems using this command:
STRSBS QCTL
The cross-reference table is now rebuilt and ready for use.
