Running Table Conversions Locally
The functionality to run the Table Conversions locally on the Deployment Server is still available, and works much as it did in previous releases. However it is recommended that you run Table Conversions on the Enterprise Server in order to minimize Upgrade time.
If you choose to run your Table Conversions locally instead of on the Enterprise Server, some steps in the Mandatory Pre-Upgrade Procedure must still be completed before running the Installation Workbench. These are:
Installing latest Tools Release
Loading latest Planner Update
These steps are described in the Mandatory Pre-Upgrade Process - Upgrading the Pristine Environment.
