Setting Up a Printer and Default Output Location on the Enterprise Server
This section describes these tasks, which must be performed in the deployment environment:
You also can print Release 9.2 reports, modify existing printers, and delete printers. These tasks are described in detail in the JD Edwards EnterpriseOne Tools Runtime Administration Guide. Refer to that document to learn more about setting up a printer to run from the Release 9.2 Enterprise Server.
If a printer was installed in your previous release of Release 9.2, you do not need to re-install that printer. All printer settings are carried forward during the upgrade to this release.
