Setting Up the Data Source for Control Tables
To set up the Control Tables data source:
This image is described in the surrounding text.
  1. On Data Source Revisions, verify the accuracy of the Control Tables data source.
    Field
    Description
    Data Source Name
    Verify the name of the data source.
    Server Name
    Verify the name of the Enterprise Server.
    When you defined your plan, some fields were changed to reflect the previous release values. Verify the values for Data Source and Database type are set as follows:
    I for IBM iSeries Access
    Library Name
    Enter the name of the library housing your Control Tables for the selected environment.
    ODBC Data Source Name
    Enter the name of the data source. For example, Control Tables - Test.
    Control Tables data sources are specific to the environment and pathcode.
  2. Click the Advanced form exit and verify that UNICODE is off only if the Control Tables are not set to Unicode in a previous release.
    If you upgrade from Release 8.9 and upwards the Unicode flag is on.
  3. Click the OK button.
