System Code 89 Obsoleted Tables
For system code 89 there are two types of obsoleted tables:
Business Data tables that JD Edwards EnterpriseOne no longer uses, but are required to access the data within for the upgrade. It is recommended to back these up somewhere until they're satisfied everything runs as should be.
New temporary tables that are used by TCs. After the TC runs successfully, these can be deleted. They are not full tables, just a couple of columns used for performance (with millions of rows...) These are:
Note: You will not have all of the below obsolete tables.- F00151
- F05290T
- F06116T
- F06116TZ
- F0618TA
- F063951T
- F0901T
- F0911T
- F0911Z1T
- F0917S
- F186407D
- F186407T
- F32UI002
- F3214
- F3294
- F3294Z
- F32941
- F32942
- F32943
- F32944
- F32945
- F3295
- F3296
- F3296T
- F32961
- F329611
- F4009T
- F4100T
- F41001T
- F4101TT
- F4102TT
- F31172TE
- F4072TEM
- F41021A
- F40344A
- F42005A
- F42140A
- F42150A
- F42160A
- F31172TE
- F42199A
- F4311TA
- F43199A
- F43121TA
- F4211A
- F4211B
- F4074TEM
- F4094TEM
- F42119A
- F42119B
- F4600T
- F4600TPU
- F46011T
- F46091T
- F4611T
- F4611TPU
- F7460
- F750401A
