Version XJDE0024 for Running Pristine Data
The Environment Tab contains these options:
Option |
Value |
Enter the Environment for the database to be created. |
Leave this field blank. |
Enter the Data Source for the database to be created. |
Enter a 1 to load Production Data or a 2 to load Demonstration Data. |
Enter 2. The default is to load production data. If this report is called from another process, the system passes in this flag. |
Enter the source Data Source for Loading of Data. |
Enter OneWorld Local. If this report is called from another process, the system passes in the data source. |
Enter the Source Environment for the database to be copied from. |
Leave this field blank. If this report is called from another process, the system passes in the Source Environment . |
The Update Tab contains these options:
Option |
Value |
Enter a 1 for Proof Mode or a 2 to create the Environment Database. |
Enter 2. The default is Proof Mode. |
Enter a A to recreate existing tables in data sources that allow automatic table creation. |
Enter A. The default is not to recreate tables. |
Enter a 1 to only copy tables that exist in the source data source. |
Leave this field blank. The default is to copy all tables. |
Enter a Y to add records without clearing the target table. |
Leave this field blank. This is used for language tables. The default is to clear the target table. |
The Print Tab contains these options:
Option |
Value |
Enter a 1 to only print exceptions. |
Leave this field blank. The default is to print all lines. |
The Licensing Tab contains the following options:
Option |
Value |
Enter a Y to create all tables or a N to create licensed tables only. |
Leave this field blank. The default is to create all tables. |
Enter a Y to print all tables in the report or a N to print licensed tables only. |
Leave this field blank. The default is to print all tables. |
