Working with Workflow Merge
Note: This merge is for cumulative updates only.
The Workflow Merge (R98800) program merges the JD Edwards EnterpriseOne workflow data shipped with a new release with the customer workflow data. The merge runs during the Installation Workbench phase.
The following list shows the workflow tables:
  • F98800
  • F98800D
  • F98800T
  • F98810
  • F98810D
  • F98811
  • F98830
  • F98840
  • F98845
Note: The workflow merge may overwrite your customer-defined data, as follows:
If any customer-defined processes are in danger of being overwritten, you should copy the existing process and rename it with another version number before performing the merge.
You can check for processes to be overwritten by using proof mode with the merge.
