Process Flow for Setting Up and Generating the Shared Information XML File
Because some of the information that you enter to set up your system to generate the general information XML file is dependent on other information, the order in which you set up the system is important.
This process flow shows the recommended order of the steps that you take to set up your system to generate the shared information XML file:
Process Flow for Setup for the Shared Information File.
