Process Flow for Setting Up the System to Generate CNAO Audit Files
Before you can set up and generate the CNAO audit files, you must set up primary elements in your system. You set up UDC values, address book records, and complete the existing accounting setup required for China.
This process flow shows the primary setup:
Process Flow of Primary Setup.
