Introduction
This 30-minute Oracle by Example (OBE) describes how to deploy UN cumulative language packages using the web client.
In this OBE, you will:
    1. Download the Japanese UN9 language package (JPN_UN9) from the Oracle JD Edwards Update Center.
    2. Import the package using the web client.
    3. Deploy the package using the web client and verify the deployment reports.
Background
Starting with Tools Release 9.2.26.0, Update Manager supports the deployment of multi-platform deliverable (PAR) language package files using the Work With Software Updates application.
You can deploy these language packages using the web client:
  • Cumulative (UN) language packages
  • Language fix packages
  • Language update packages
This enhancement enables you to deploy language packages without any dependency on the Windows Deployment Server.
Applying language updates using the web client enables remote patch management and automation.
Prerequisites
Before deploying the UN cumulative update language packages, ensure that the UN9 cumulative update is deployed. All UN language packages are dependent on the corresponding UN cumulative update. In this scenario, the UN language package JPN_UN9 depends on UN9.
Task 1: Downloading UN Language Packages from the Update Center
To download the Japanese UN9 cumulative language packages which are in the multi-platform format:
  1. Access the Oracle JD Edwards Update Center.
  2. In the Search section, set the following criteria:
    1. In the Type field, select Cumulative Updates.
    2. In the Release field, select 9.2.
    3. In the Platform field, select Multi-platform.
    4. Search Criteria on the Oracle JD Edwards Update Center
  3. Enter the language name JPN* for Japanese in the Search for Name field to further limit the language package search and click Search.
  4. Review the search results.
    Search Results on the Oracle JD Edwards Update Center
  5. Click Download icon to the left of the package name JPN_UN9 to add it to your downloads. The package is added to your Download Basket.
  6. From the Download Basket, download the portable archive (.PAR) file JPN_UN9_28_70.par.
    Download Basket on the Oracle JD Edwards Update Center
  7. Note:
    All UN9 Language packages are dependent on UN9. This OBE assumes that UN9 has already been downloaded and deployed.
Task 2: Importing UN Language Packages Using the Web Client
To import the JPN_UN9 language package using the web client:
  1. Sign in to EnterpriseOne on the web client.
  2. From the Software Updates menu (GH9612), select Work with Software Update (P96470W).
    Navigation to Work with Software Update Application (P96470W)
  3. On the Work With Software Updates form, enter 03 (Languages) in the Software Update Type field and click Find.
    Work With Software Updates Form
  4. Select the Form menu and click Import.
    Work With Software Updates - Import
  5. On the File Upload dialog box, click Choose File and select the downloaded language package file JPN_UN9_28_70.par. You can only import one package at a time.
    File Upload
    File Upload
  6. Click Load. The system imports the file and returns to the Work With Software Updates (P96470W) form.
  7. Click Find to refresh the grid. The imported language package appears in the grid.
    Work With Software Updates – UN Language Package Populated
    The system also updates the Software Update Status pane on the screen which displays a visual of the deployment status, highlighting the current deployment step and the percentage of updates remaining.
    Software Update Status Window
Task 3: Deploying UN Language Package and Reviewing Reports Using the Web Client
To deploy the imported language package file using the web client:
  1. Access the Work With Software Updates application from the Software Updates menu (GH9612).
  2. On the Work With Software Updates form, enter 03 (Languages) in the Software Update Type field and click Find.
  3. Select the UN language package JPN_UN9 from the grid.
  4. Select the Row menu and click Deploy.
    Work With Software Updates Form - Deploy
  5. The Software Update Environment Selection form is displayed. Select the Replace checkbox. The Replace checkbox is not selected by default. Select this checkbox to have R96701L replace records instead of appending them.
    Software Update Environment Selection Form
  6. Select the checkbox corresponding to the environment(s) where you want to deploy the package. For Trial Edition, use PS920.
  7. Click OK on the Software Update Environment Selection form to launch the package deployment.
  8. The Deployment Status pane on the Work With Software Updates form displays the percentage complete.
    Deploying each UN language package may take up to 30 minutes.
    Work With Software Updates - Software Update Status
    When the deployment is complete, the system displays 100% complete status in the Deployment Status pane.
    Work With Software Updates Form - Deployment Status
  9. Click Find on the Work With Software Update form to refresh the grid columns.
  10. Click Refresh in the Software Update Plan History pane.
    Software Update Plan History Form
  11. Click Download icon for R96701L (Program Name) in the grid column to download the Language Update Web Deploy Summary Report (R96701L). This report provides summary of the deployment.
    Language Update Web Deploy Summary Report Language Update Web Deploy Summary Report
  12. The system generates four versions of the Language Data Copy (R98403XB) report for the various language tables copied. Click the View Output icons corresponding to these versions in the grid column to download and review them.
More Learning Resources
For more learning resources, visit LearnJDE.
For product documentation, visit JD Edwards on Oracle Help Center.
