Orchestrating an Advanced Deployment
This section shows you how to orchestrate an advanced deployment plan by adding Web Servers and Enterprise Servers post deployment.
You can add additional Web Servers and Enterprise Servers after you complete your Deployment. You cannot add any other server type after the deployment.
Prerequisite
Successfully completed the Deployment of a Quick Start or an Advanced Deployment Plan using the JD Edwards One-Click Provisioning Console. These tasks are described in preceding sections of this Learning Path.
Orchestrating an Advanced Deployment Plan by Adding Web Servers and Enterprise Servers Post Deployment
To add additional servers post deployment:
  1. On JD Edwards One-Click Provisioning Console, click the Orchestrate icon .
  2. On JD Edwards Servers, click the New Server icon, and in the Select a Component window, select Web Server.
  3. On Web Server Instance Details, enter appropriate values for your installation.
  4. Click the OK button. Similarly, you can add new Enterprise Servers.
  5. On JD Edwards Servers, click the Back button.
  6. On JD Edwards One-Click Provisioning Console, click the Deploy icon.
  7. On JD Edwards Deployment window, review the deployment summary. You can verify the newly added servers in the Deployment Details tab.
    Note: To deploy an orchestration, refer to the section of this guide entitled: Deploy an Orchestration.
