Considerations for Setting Up Employee Payroll Information
Set up this employee payroll information for each selected employee:
Enter 2 (payroll and recharge processing) or 3 (recharge processing only) in the Record Type field.
Note: Setting this option in the employee record is optional. Instead, you can enter 2 for payroll and recharge processing or 3 for recharge processing only in the Record Type field during timecard entry.Add a distribution rate or verify that a rate exists on the record.
