Considerations for Setting Up UDC 48/MT (Markup Generation Type)
Verify that the generation type that you use to retrieve billing rates from the Billing Rate / Markup Table program (P48096) has a value of P (payroll recharge rate).
Note: You can define a value other than
P (payroll recharge rate). If you use another value, verify that the
value that you use is specified as the generation type for the markup rules in the
Billing Rate / Markup Table program and that this value is specified in the
Generation Type Payroll processing option in the Time Entry MBF Processing Options
program (P050002A).
