Invoice Print Smart Fields
Over 80 smart fields are available to insert on an invoice during invoice design. These smart fields are named using an S prefix, followed by the table number, followed by the data type indication character, such as A (alpha), C (character), D (date), or N (numeric). For example, the smart field used to retrieve and print numeric information from the Business Unit Master table (F0006) is named SF0006N. A majority of the smart fields are used to retrieve information, which is stored in various tables, that you can print on the invoice. For each table that contains invoice-related information, smart fields are available and are used to:
Retrieve and print alphabetic information.
Retrieve single-character information.
Retrieve date information.
Retrieve numeric information.
Print amounts from the Billing Detail Workfile table (F4812) and the Billing Workfile History table (F4812H).
Print blocks of text.
Calculate and print values based on other fields.
Print accumulated values that have been stored in user-defined memory locations.
These smart fields can be used for retrieving table information and are available during invoice design:
Table |
Table Name |
Alpha Smart Field |
Character Smart Field |
Numeric Smart Field |
Date Smart Field |
F0006 |
Business Unit Master |
SF0006A |
SF0006C |
SF0006N |
SF0006D |
F0014 |
Payment Terms |
SF0014A |
SF0014C |
SF0014N |
SF0014D |
F0101 |
Address Book Master |
SF0101A |
SF0101C |
SF0101N |
SF0101D |
F0111 |
Address Book - Who's Who |
SF0111A |
SF0111C |
SF0111N |
SF0111D |
F0115 |
Address Book - Contact Phone Numbers |
SF0115A |
SF0115C |
SF0115N |
SF0115D |
F0116 |
Address By Date |
SF0116A |
SF0116C |
SF0116N |
SF0116D |
F03012 |
Customer Master By Line of Business |
SF03012A |
SF03012C |
SF03012N |
SF03012D |
F0401 |
Supplier Master |
SF0401A |
SF0401C |
SF0401N |
SF0401D |
F00692 |
Cost Center Supplemental Data Codes |
SF0692A |
SF0692C |
SF0692N |
SF0692D |
F0901 |
Account Master |
SF0901A |
SF0901C |
SF0901N |
SF0901D |
F1201 |
Asset Master File |
SF1201A |
SF1201C |
SF1201N |
SF1201D |
F1721 |
Contract Detail |
SF1721A |
SF1721C |
SF1721N |
SF1721D |
F4801 |
Work Order Master File |
SF4801A |
SF4801C |
SF4801N |
SF4801D |
F4812 |
Billing Detail Workfile |
SF4812A |
SF4812C |
SF4812N |
SF4812D |
F4822 |
Invoice Summary Work File |
SF4822A |
SF4822C |
SF4822N |
SF4822D |
F48520 |
Invoice Summary Access |
Not applicable (NA) |
NA |
SF48520N |
NA |
F5201 |
Contract Master |
SF5201A |
SF5201C |
SF5201N |
SF5201D |
F5202 |
Contract Billing Line Detail |
SF5202A |
SF5202C |
SF5202N |
SF5202D |
F5216 |
Milestone/Progress Billing Information |
SF5216A |
SF5216C |
SF5216N |
SF5216D |
F4201 |
Sales Order Header File |
NA |
NA |
SF4201N |
NA |
F00693 |
Cost Center Supplemental Data Text |
SF0693A |
NA |
NA |
NA |
F4802 |
Work Order Instructions File |
SF4802A |
NA |
NA |
NA |
F00165 |
Media Objects storage |
SFABTXT SFCNTTXT SFINVTXT |
NA |
NA |
NA |
F0005 |
User Defined Codes |
SF0005A |
NA |
NA |
NA |
Special smart fields that provide information not stored in tables are:
Smart Field |
Smart Field - Name |
Function |
SFAMT |
Amount |
This smart field is used to print amounts from the F4812 and F4812H tables. It enables you to include or exclude burden and component amounts. It also works in conjunction with the Currency processing option in the Invoice Print program (R48504) to enable you to variably print foreign or domestic amounts. |
SFADD |
Calculate - Add |
This smart field is used to add various fields and print the sum. |
SFSUB |
Calculate - Subtract |
This smart field is used to subtract various fields and print the difference. |
SFMUL |
Calculate - Multiply |
This smart field is used to multiply various fields and print the product. |
SFDIV |
Calculate - Divide |
This smart field is used to divide various fields and print the quotient. |
SFTOTAL |
Register Total |
This smart field is used to print the accumulated amounts on the field and to initialize the register (a variable memory location that the invoice designer can use to store and accumulate the value of the smart field), if desired. |
SFCALC |
Register Calculate |
This smart field is used to perform calculations using multiple register values, and then print the result. |
