Major Key Values
The system matches the major key information that you set up for a markup table to the information in billable workfile transactions.
This table lists the searches that the system can use for a major key:
Search Level |
Key Type |
Search Criteria |
Table Used for Validation |
First |
1 |
Work Orders |
Work Order Master File (F4801) |
Second |
2 |
Work Order Classes |
User Defined Code 00/W7 |
Third |
3 |
Contract Numbers |
Contract Master (F5201) |
Fourth |
4 |
Parent Contract Numbers |
Fifth |
5 |
Customer Numbers |
Address Book Master (F0101) |
Sixth |
6 |
Job/Business Units |
Business Unit Master (F0006) |
Seventh |
7 |
Job Classes |
User Defined Code 00/11 |
Eighth |
8 |
Company |
Company Constants (F0010) |
Ninth |
9 |
System Default |
No validation |
The system uses key type 9 when it does not find a match in any of the previous levels. The system applies the remaining eligible transactions to tables with this key type. When the system does not find a match for key type 9, it uses the default markup percentage that you specified in the system constants.
