Understanding Data Relationships and Contracts
The Data Relationships tool is a collection of programs that you can use to manage the consistency and quality of data that is entered in the F5201 table. You use the tool to define relationships between columns (data items) in the F5201 table.
After you define data relationships for the columns, you define the default destination values that you want to appear for a single basis value when you enter a new contract. The system automatically applies the data relationship during data entry.
If you define data relationships for contracts that already exist in the F5201 table, you can manually or automatically update the table with the data relationships rules.
The data relationships functionality supports multiple columns in the F5201 table.
