Tank Gauging and Strapping
After you measure the height of the liquid in the tank, you refer to the strapping table computed specifically for that tank. A strapping table is a record of volume capacity in a tank by height increments. The strapping table accounts for imperfections in the shell of the tank. The strapping table converts tank dip readings to gross volumes for a particular tank.
This diagram illustrates measurements used for bulk stock in a tank:
Strapping tables might be set up in these ways:
Height Designation |
Description |
Shell height. |
Distance between the bottom of the bottom angle of the tank and the top of the top angle of the tank. |
Gauging height or Reference height. |
Distance from the striking point on the tank floor (or strike plate) to a designated reference point on the gauge hatch. |
Effective Inside Tank height. |
Distance from the strike plate to the top angle, or where the product would begin to overflow. This height defines the upper and lower limits of the tank table. |
