Understanding Tank Temperature and Density
The system uses the default temperature and density that are specific to a tank to calculate volume and to process the stock movements. If you do not enter the temperature and density information when performing a stock movement, the system retrieves the default temperature and density for the tank from the Default Tank Information table (F41508).
If you enter the date and time, the system uses this information in all records added in all detail lines.
If you enter the date and time on the form, you can display different information for each record.
To delete a record, select only the line for the tank to delete on the Work With Default Tank Information form.
