Defining a Standard Unit of Measure Conversion
Access the Search for Standard UoM Conversion form. Click the Add button.
- From UoM (from unit of measure)
Enter the unit of measure to be converted. The standard unit of measure conversion is not associated with a scenario.
- To UoM Quantity (to unit of measure quantity)
Enter the factor that the system uses to convert one unit of measure to another unit of measure.
- To UoM (to unit of measure)
Enter the secondary unit of measure to which the original unit of measure is converted.
