JD Edwards EnterpriseOne Demand Flow Manufacturing Implementation
This section provides an overview of the steps that are required to implement the JD Edwards EnterpriseOne Demand Flow Manufacturing system.
In the planning phase of your implementation, take advantage of all JD Edwards EnterpriseOne sources of information including the installation guides and troubleshooting information.
When determining which electronic software updates (ESUs) to install for JD Edwards EnterpriseOne Demand Flow Manufacturing, use the EnterpriseOne and World Change Assistant. EnterpriseOne and World Change Assistant, a Java-based tool, reduces the time required to search and download ESUs by 75 percent or more and enables you to install multiple ESUs at one time.
