Kanban Supply and Consumption Point Export
When you export DFM kanban supply and consumption points to the Item Location table, the program checks whether the Location Control check box in the Branch/Plants Constants program is selected. If this check box is selected, the program validates whether the exported record exists in the Location Master table. If it does not exist in the Location Master table, the export fails. To export a kanban supply/consumption point record to the Item Location table, you have to either set up a location master record for this kanban location first, or clear the location control in the branch/plant constants.
