Understanding Base Data Setup for Demand Flow Manufacturing
When using JD Edwards EnterpriseOne Demand Flow Manufacturing, you can work with either of two sets of data. If JD Edwards EnterpriseOne Demand Flow Manufacturing is integrated with other JD Edwards EnterpriseOne systems, you import the necessary data from those systems. However, if you use JD Edwards EnterpriseOne Demand Flow Manufacturing by itself, the setup applications that are described in this chapter enable you to set up the data that you need to run JD Edwards EnterpriseOne Demand Flow Manufacturing. applications. These will control all JD Edwards EnterpriseOne Demand Flow Manufacturing functionality.
You always have to set up scenarios because this functionality is unique to JD Edwards EnterpriseOne Demand Flow Manufacturing.
Within base data setup, you set up the following data:
Scenarios
Unit-of-measure conversions
Branch/plant information
Item definitions
Bills of material
Customers
Suppliers
Employees
Resources
Sales orders
