Defining Level Column Headings for Matrix Entry
Access the Column Heading - Work with User Defined Codes form.
This is the 41F/CH UDC.
Click Add.
Enter the order in which you want the column headings to appear in the Codes field (for example, 1,2,3).
Enter the text that you want to appear for the column heading in the Description 1 field.
Click OK to save your new column heading values.
